Reasons Why Red Lion Water Pumps Are a Top Choice Among Homeowners
Did Your Well Pump Give Out?
If so, it’s now time for an upgrade – an upgrade to a Red Lion water pump. This brand pump is the top notch choice when it comes to water pumps for residential, industrial, construction, and farm use.
You’ve probably seen those ads. You know the ones. They feature smiling and happy homeowners watering their flowers or gleefully cleaning their muddy four-wheelers.
Now it’s your turn to experience the joy of having a volume high pressure water supply whenever you need it.
A Red Lion water pumping system will handle all your water needs effortlessly so you can address your specific pumping requirements. If you thought you had witnessed the peak of water pump power and performance, think again.
A Water Pumps That Is Built to Last
Red Lion water pumps are known for their durability, lasting performance and ability to transport your water with ease.
Designed to withstand the rigors of use, Red Lion pumps are known as well for their energy efficiency.
This feature translates into cost savings for you. With their energy-saving motors, Red Lion pumps can save your 30% to 50% on power. That doesn’t mean you’ll make any compromises on flow rates or pressure either.
A Variety of Uses
Red Lion water pumps can be used for delivering water, for dewatering purposes – for above-ground use and for sump pumps, wells and pools.
Some pumps are better for certain applications than others. Therefore, it’s important to understand how the various pumps work before making a buying decision.
Submersible Pumps
Submersible pumps are the most common pumping systems. They are the pumps, installed below water, that normally are part of an irrigation pond, sump, pit, or well.
Also, submersible pumps may be used for dewatering applications – pumping out water from flood zones or construction sites. In these instances, transferable pumps are frequently used, which also come in non-submersible and portable models.
Dewatering, when used in construction, involves removing groundwater to create a more stable foundation for site prep and excavation. Therefore, their job is to reduce the surrounding water table temporarily.
Water pumps cannot be used, sometimes, if gravel, sand or sewage is present, so you need to check the specs carefully before you select a pumping system.
Above-Ground Pumps
Above-ground pumps are installed above a body of water for water transport. They usually do not have as much power as submersible pumps.
Centrifugal Pumps
Centrifugal pumps use a rotational impeller to draw water from beneath the surface of a body of water. These pumps are usually introduced in municipal water systems or in residential areas. Centrifugal pumps often are designed to pump the water from below the surfaces of wells.
Keeping Your Pump Operational
When you receive a water pump from Red Lion, you’ll also get a sheet of instructions – instructions that will explain how to safely operate your new water pump. You should retain the instructions for future reference so you can maintain your pump without difficulty for many years.
A High-Quality Premium Pump
Red Lion water pumps are built of the highest quality materials and are carefully inspected, tested, and packaged. When you receive your pump, it’s important to examine it thoroughly to make sure no damages have occurred while in transit.
In Summation
Again, Red Lion water pumps are made in various versions, so it’s important to review your water pumping needs and requirements and ask any questions about the features you don’t understand.
By choosing a premium brand, you can rest assured that any water pumping task will be both smooth and efficient. That’s why people in the know make Red Lion their go-to water pump brand.
