How To Soundproof A Door – Complete DIY Solution
You need to feel private at least in your own home. Aren’t you sick of hearing the buzz of the whole neighborhood? Probably you don’t want everyone to overhear what music are you listening to or what you are talking about at home? This leads you to the dilemma how to soundproof your doorway efficiently without huge costs for the improvement. Doors are always the weakest link when it comes to soundproofing.
The main reason is that the core of the door you have chosen might be hollow in order to be cheaper. All the small spaces all around the door are also responsible for sound leaking. Just follow SoundproofWiz simple tips on how to soundproof a door and you won’t be disturbed by any noise troubles again.
Change the Door
As we mentioned above, the roots of your problem can be in the hollow core. How to soundproof your door in that case? You need to replace it with another one, which would efficiently keep the noise away from you, once it is closed. You have 2 options:
- Pick a special soundproof door: This choice is going to cost you more, but you know what you are paying for.
- Get a medium-density fiberboard one: A cheaper alternative, this door also has the ability to stop the constant external sounds, because it has a solid core.
Add an Extra Door
Hanging out two doors from one door jamb is a great idea if possible. Unfortunately, not every door jamb is suitable for this purpose. However, if you manage to do so, you will be amazed how much quieter your place is going to become. The space between your two doors is going to be extremely helpful in blocking the noise coming from the outside.
Install a Metal Door Sweep
A metal door sweep, which is attached directly to the lower part of the door, is very useful for some additional soundproofing. Make sure that it brushes the floor gently. Then you can expect a serious decrease in sound entry.
An Acoustic Panel can do Miracles
Put an acoustic panel (a bit bigger than you need) behind your door. The effects of such a method are simply amazing. You need to combine it with the other advice on how to soundproof a door, though.
Just “Seal” your Door!
Caulking with an acoustic sealant is also one of the basic upgrades you can make for your door. Don’t forget to place foam seals around the door jambs!
Simple Solutions
Some more easy techniques on how to soundproof a door are also achievable and effective. You can hook some towels, blankets and other fabric that will be able to block the sound. This primitive at first glance isolation works according to the motto: the more, the better. Hanging out a bigger amount of heavy textile materials will be more useful to get rid of the noise from the outside.
Verdict
You are wondering how to soundproof a door? Focusing on just one of the listed tips wouldn’t bring you the desired result. Mix the ones that suit you best to get the most of it.
