How to Prepare for a Roof Installation Project?
A roof installation helps protect your home for decades and increases its value. Whether it is a roof replacement or a new installation, it is important to choose the right roofer who can take care of all the work. While they take care of the professional side involving all areas of the project, you have to do your bit to prepare your property and family. So, how do you prepare a roof for installation? Find out in this guide.
Clear off All the Branches
If there are branches overhanging your roof, you should get them trimmed. This is essential so that your roofers can have easy and safe access to the entire roof.
Clear & Protect Your Attic
Most attics are filled with fragile items, many of which have sentimental value. A roof installation job can put these items at risk of potential damage. So, you should clear them from the attic and temporarily store them on the ground floor.
It is also important to take steps to protect your attic. Your attic will be collecting a lot of dust during the roofing job. Make sure to lay drop sheets or tarps on the attic’s floor.
Protect All Fragile Items
A roof installation project work can create vibrations due to the use of various equipment. These vibrations have the potential to damage fragile items. So, you should take steps to protect such items. These can include:
- Dishes
- Glass
- China plates
- Vases
Any breakables should be kept away from the wall. All china can be stored in a cabinet.
Remove & Store Your Wall Décor
The vibrations can knock off your wall décor. So, make sure to remove your wall decorations before the roofing project begins. These items can include pictures, mirrors, and wreaths. This is most important for the top floor.
Secure All the Windows
During the roof installation process, your windows will need to be protected. Roof materials are likely to fall during the process and cause damage to the windows. Check with your roofers to ensure that they will place wooden boards over your windows until the completion of the project.
Remove All Roof Accessories
Next, you should ensure that all the roof accessories are removed. This can include:
- Skylights
- Satellite & TV dish
- Solar panels
This means you should expect TV interruptions during the roof installation process.
Clear Your Garden & Protect Your Plants
Next, you should take a look at your garden and remove anything that can be moved. This includes items such as:
- Potent plants
- Birdhouses
- Solar-powered lights
- Water fountains
You are likely to have delicate and expensive plants in your garden. There is no need to put them at risk of damage from dropped shingles or other debris. If you cannot move a plant or tree, mark it using orange tape. You can cover flower beds and plants with a tarp or netting. It is recommended to share information on plants that need additional care with your roofer.
Plan the Power Sources
Roofers, when working on your roof, will need access to power for various activities. They will be using tools on the roof that will need extension cords. In the absence of exterior outlets, it will be required to run extension cords into your home. Make sure to flag the cords clearly to help prevent tripping.
Further, it is recommended to inform your neighbors that you are getting a new roof. This can help them also prepare for the likely disturbance. So, it is recommended to follow these tips when preparing for your roof installation.
